Combustion analysis
rgar98
rgar98 Member Posts: 66
edited August 2021 in Oil Heating
I cannot find an independent oil technician in Montgomery County Maryland (Silver Spring) to do an analysis of my oil burner set-up. The "Find a Contractor" link is not helpful.
  • STEVEusaPA
    What about the company from where you buy your oil?
  • ChrisJ
    ChrisJ Member Posts: 17,064
    @Steamhead Is this in your area?
    Steamhead Member Posts: 18,187
    We don't usually go down that far..... @rgar98 , how about @Dan Foley ? If his company, Foley Mechanical, doesn't do this he probably knows someone............
    Consulting
    ChrisJ
  • Mike_Sheppard
    Mike_Sheppard Member Posts: 698
    edited August 2021
    I cover VA, MD, and DC from Richmond up to Hagerstown / Baltimore. And a little bit of PA.
    But I do commercial and industrial boilers. I have a ton of customers in Silver Spring.
    +1 for Dan Foley. If Dan can’t do it for some reason let me know and I will help you out.
    Never stop learning.
  • rgar98
    Thanks Mike, I appreciate that.
  • captainco
    captainco Member Posts: 840
    There is a company in Silver Springs called D&D Services. Not sure if they do oil but they have been certified by NCI on Combustion testing. Foley are good guys too,
