Viessmann vs Energy Kinetics
I just spoke to a local guy who installs EK boilers and he told me they are great with oil but suggested another brand for gas. One of the best things I've learned from this forum is the installer is more important than the brand. I must admit, I'm very impressed with the Vitocrossal 300.0
What kind of a heating system do you have? Radiators, radiant, baseboard.............?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Honestly, I haven't installed many Viessmann, but I install Ek as my primary boiler, and being from NJ and the head quarters is only 20 min away from my shop, I stand behind their boilers I haven't had any significant issues of than people having hard water in their homes and causing problems with the domestic heat plates but 100% on the earlier comment it is all about the guy installing the boiler4
To add to @tgallagher 's posting, EK is an American company. Vie$$mann is not. Some customers don't care about that but I thought it worth mentioning.All Steamed Up, Inc.
Consulting2 -
That Viessmann 300 is considered the top, global distribution2
Hi Alan, I currently have a 1954 American Standard oil boiler with baseboard.
I have never installed an Energy Kinetics boiler. As a matter of fact, I've never seen one as I don't think they're well represented out West. But I sure hear a lot of good things about them on this website.
As far as the Viessmann CU3A Vitocrossal, I like them because contrary to what's been trending for the last 20-30 years, they are a high volume boiler and don't have as many problems with short-cycling when there are small zones calling for heat.
I don't think you could go wrong with either one.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I’d go with Energy Kinetics before the Viessmann. EK has the best customer service and tech support by far from any other boiler manufacturer. Plus every boiler is super simplistic and 99% of replacement parts can be picked up and available at most wholesalers at least the ones I deal with. American made and family owned which is a huge plus in my eyes.
3 -
Thank you all for you kind words about Energy Kinetics products, and for your question, @curiousman , and for your other discussion thread describing your heating system as a combination of radiators and baseboard.
The first point I'll reiterate is that our non-condensing heat and hot boilers with thermal purge perform with efficiency very close to our condensing boilers, and in this Department of Energy Lab study, they outperformed 95 AFUE modcons. I'm sure you'll be very pleased with any model with quietness, savings, near endless hot water, and long term serviceability.
I realize you have some concerns about condensing boilers delivering long term proper and reliable operation. We share those concerns and that's why we designed our fire tube Accel CS boiler with wide open water passes, industry standard parts where available, and Smart Boost among other features. Smart Boost allows your heating professional to set a very aggressive reset curve; if any specific zone is not coming up to temperature fast enough, it boosts the temperature to increase the output of your baseboard or radiation. This is the same thing your heating pro would do if you called and said the system was not heating adequately (and it's a reason why reset curves are often set higher than needed), but it does it based on the individual needs of each zone and it will only do it after checking during each and every thermostat call. We also have an oversized plate heat exchanger and the way we heat the storage tank from top to bottom means that it rains out condensate for nearly the entire hot water cycle; this condensate flushes and keeps the fire tubes clean on the burner side of the boiler. There are many more features, but these are a few of the important and distinguishing highlights.
As an additional note, your1954 American Standard could act like a radiator and heat the boiler room and the room above it. You won't have that waste heat with Energy Kinetics boilers or modcons.
Best,
RogerPresident
Energy Kinetics, Inc.3 -
For the record I have been using Energy Kinetics products for the past 45 years and absolutely love them. The worst issues I have had were caused by technician carelessness, not faults with the boilers themselves.
45 years ago my wife and I had a System 2000 oil fired boiler installed. We were hesitant spending extra for a boiler relatively new to the market but 40 years later I can attest to its' performance, reliability and endless hot water.
About five years ago I decided that switching from oil to gas heat was best for our family. Our System 2000 boiler was still going strong. I decided to go forward with the Energy Kinetics Accel CS boiler fueled by natural gas. It seemed like a no brainer, Over five years later I can only say I am ecstatic with the performance, reliability and endless hot water!!! We have not had one issue. It runs quietly, efficiently and cleanly. This is a FIRST RATE boiler!!! I do not work for Energy Kinetics and I am not being paid to advertise this boiler.
I have a 100 year old home and our boiler is in the basement. We have cast iron radiators. We use a scale remover coming into our direct hot water heater. We use a dehumidifier in the basement in the summer. Having competent technicians install and maintain these units is the best way to insure their efficiency, performance and long life. I have had ZERO problems with my Accel CS for over 5 years now. Energy Kinetics products have performed above all my expectations. Don't buy their boilers, however, without a trustworthy and well trained technician backing them up.
5 -
Carrier purchased Viessmann. Wouldn't that make Viessmann now, ALSO and American company?
but who owns carrier?
Looks like private equity to me.
Consulting1 -
Thanks hot_rod! I own a very tiny piece of Carrier and an even smaller piece of Viessmann.
- 15.8K Strictly Steam
