No circulating pump in radiant floor system
BlueBaron
Member Posts: 3
Hello! I have a radiant floor system that is very old. I have a newish Triangle Tube Prestige Boiler (6 years old). I am trying to understand the basics of my system. I do not see any zone valves or circulating pump. How does water circulate without a pump? What am I missing? Thanks for your help!
Thank you so much! You are exactly right! This is just the kind of help that I was looking for. And you were right that it is older. But it runs great. It is running so great that I am thinking of replacing my tank hot water heater with a Triangle Tube Smart tank (and piping it to my boiler).0
Your direct piping plan is a bit unusual. Most installations have primary/secondary piping to assure correct flow through the boiler. Yours seems to be running great so carry on
If you add an indirect, you may need to do a bit of repiping. With the circ built into the boiler, I would suggest piping it just like the manual. Primary/secondary on the heat with a separate DHW circ with priority."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Sometimes even a blind squirrel finds a nutZman said:Your direct piping plan is a bit unusual. Most installations have primary/secondary piping to assure correct flow through the boiler. Yours seems to be running great so carry on
If you add an indirect, you may need to do a bit of repiping. With the circ built into the boiler, I would suggest piping it just like the manual. Primary/secondary on the heat with a separate DHW circ with priority.0 -
The expansion tank should be on the return in your case. It wants to be as close as possible the suction side of the circulator. That type of boiler has very little resistance to flow, so piping it as shown in the manual is correct."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1
- 121 Chimneys & Flues
- 15.8K Strictly Steam
