Pressure gauge to pump connection
rgar98
Member Posts: 59
in Oil Heating
Anyone know which adapter is needed to connect Yellow Jacket gauge (1/4" flare) to nozzle port of Cleancut pump (10322)? There is a flare fitting on pump for nozzle line which is 3/16". Or suggest best way to make pressure measurement.
Thanks.
Richard
Thanks.
Richard
I made my own gauge setup, just use a 3/16" flare x 1/4 NPT fitting and install a 200 psi gauge in it. NAPA should have the fitting, or any parts house.0
Thanks. I'm sorry, but is this to connect the gauge directly to the nozzle line fitting on the pump? Please tell me exactly what the connections are.
The gauge hose is a flare and the pump has a flare to fit nozzle. Sorry, but I'm confused about the dimensions.
Is a flare fitting on a 3/16" line called a "3/16 flare or is it named by the size of the "nut" on the line?0 -
@rgar98
Usually we test the oil pressure at the bleed port on the pump. Remove the fitting in the pump and install a 1/4" flare X 1/8" male pipe thread adapter.0 -
A flare nut is sized by the tubing it connects—the thread pitch etc. are standard per size (& system, i.e. SAE vs metric) & are rarely mentioned. If it is indeed 3/16, google "3/16 flare to 1/4 flare", or build something from parts at a Big Box store. Around here, it's common to open a package for a test fit (& then put it back & get an unopened one, grrrrrr).0
@ ratio
So you're the guy who's been doing that at my Home Depot. /S
Thanks for the comment.
@EBEBRATT-Ed
Thanks, I wasn't sure that the bleed fitting could be removed.
RG0 -
I have the 3/16 flare to 1/4 female adapter that I hook to a 3/16 nozzle, line that stays in my tool bag, that I use to test all my pumps with. I remove the nozzle line from the fuel pump and hook up this setup at the fuel pump, or the outlet of a fuel solenoid valve if it has one. That way, I know what pressure is going to the nozzle, and when I run the burner until the primary control shuts it down, I can check if it holds and doesn't bleed down. Also, by hooking it up to the fuel line output, I can run the unit without any fuel going anywhere that I don't want it to.
Rick1 -
@rgar98
You can check the oil pressure at the nozzle port or the bleed port. We were always taught to use the bleed port as the nozzle port is occupied by the nozzle line.
No difference except the nozzle port cuts off (closes) when the oil pressure drops below 75 psi or so. At least that's what it used to be with 100psi pumps. In the days before clean cut pumps or solenoid valves nozzle cut off and opening pressure was determined by oil pressure0 -
@ Rick
Which gauge do you use?0 -
I just use a 200 psi gauge. Nothing special.
Rick
I use these...The manifold set is used between the pump and the nozzle assembly.
The second one in on the bottom left is used at the end of the nozzle assembly. It's the most accurate for pressure and cut-off. The better question is...do you actually know what you are doing with them.
@rick in Alaska
(1)When you test pressure do you run the pump until shut off or until pressure maxes out? If you do, then you reset by holding "in" the "i" button?
Unrelated question: What is the plug on Cleancut at lower left, the one facing left at a 45 degree angle. [NOT the inlet for a two-pipe system.]0 -
Sounds like your out of your element here @rgar98.
What’s actually going on here?There was an error rendering this rich post.
The pump pressure comes up immediately, and then I just let it go until the primary control shut down. That way, I can check the primary control timing, pressure, and cutoff pressure.
Not sure about the plug.
Rick0 -
@STEVEusaPA
What "element" is that?0 -
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
