Need to fully replace Entran II tubing in slab… any advice?
sdrake99
Member Posts: 1
I am considering the purchase of a large home, but the majority of the main floor (in gypcrete) and basement (in the slab) uses the recalled Entran II tubing from 1995.
I assume I will have to fully replace this system in the upcoming years, so does anyone have experiences tearing into the slabs to do this or is there a more eloquent modern solution.
Each floor is approximately 2,500 sq ft.
Thanks in advance for any ideas or information.
My suggestion would be to see if a different hydronic system like panel rads will work with the overall layout of main and basement floors.
If so it would be a lot cheaper then having to rip up and tear out the existing system.
3 -
Or even ceiling radiant would be easier than ripping up the slab or pouring over the slab and shortening everything, but panel rads or some other retrofit would probably make far more sense.0
In situations such as yours no Ripping up or tearouts required...Maybe some Sheetrock repairs...
We use a combination of Viega Climate Panel and Panel Radiators/Towel Racks such as Buderus/Dianorm/Myson/Runtal/Roca
In some situations we install Radiant walls up to about 4 feet high (Not Hanging a picture Zone).
We have done radiant ceilings but it is VERY Labor intensive therefore the cost is much higher
than Climate Panel..
Hope this helps..1 -
I sure like the tubing in the floor. The Gypcrete should be straightforward compared to the basement slab. If you've got the cash, not in a rush to move in and have a reliable GC and radiant contractor, go for it. Especially if you are having other work done that involves tearing into the floor.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
do you have the ability to lose and inch or two and just do a Warmboard R option? pretty simple to do, and way cleaner and simpler than tearing up concreteTom
Montpelier Vt0 -
Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
