Navien Combi ??
Once I finally get gas ran into the house from the street I’d like to get a Navien combi boiler. Is it possible to have the combi installed and just use the hot water off of it temporarily?
    Jamie Hall Posts: 27,826
    Um... yeah, but why? If you want the tankless hot water heater feature, why not start with a purpose built tankless hot water heater, and add a similarly purpose built (and properly sized) boiler later? The end result will likely be more satisfactory and efficient anyway...
    mikeapolis
  • EzzyT
    EzzyT Posts: 1,380
    Personally I would stay away from a wall hung combi and especially once made from that manufacturer.
    Stick with a properly sized boiler and indirect tank.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    kcoppSuperTechmikeapolis
    EBEBRATT-Ed Posts: 21,043
    That manufacturer is having major issues
    kcoppSuperTechBillyO
  • woobagooba
    woobagooba Posts: 186
    Mikey Pipe's take on Navien ... https://www.youtube.com/watch?v=CjdIjA1ZznY
    Larry Weingarten
