Union surface just metal to metal?
sunlight33
Member Posts: 378
The contact surfaces on the Viega union fitting is just metal to metal, I presume this is going to be watertight after tightening but no gasket is needed?
Yes, metal to metal, no gasket needed. The Viega unions are usually very good high quality and don't leak. They shouldn't for the price they get.0
A modern marvel of precision engineering! And they had metal to metal unions even before NASA was around! Check out that radiator valve
@Jamie Hall... I have used Gorilla in the past for many things. Some even use it for hair care.
Have you tried their Bikini Wax product?
As they used to say about duct tape... it's like the Force. It has a dark side and a light side, and holds the universe together...Br. Jamie, osb
Always had good luck with brass/brass unions.
Stainless steel on the other hand can be tricky.
Steel is hard unlike brass that might conform just a little to the match up.
Gas and water meter spud unions use a flat washer gasket.0 -
@JUGHNE
Copper sweat unions are problematic. The cheap copper-copper ones if you put 10 of them in correctly a few will drip. The you dope them and hope for the best.........does not make me happy. I usually don't dope any unions unless I have to but like using never seize.
On copper I have much better luck with the Nibco where 1 end is copper and the other end is brass, forgot the # Those are pretty good.
Of course, because the are more $$$$ some supply houses don't stock them. Big Box forget about it.
The propress unions are big $$$$. I don't think I have ever had a leak on one of those. Quality counts0 -
Those NIBCO brands have been pretty good.
I have salvaged some old (30-40 years old) that performed well.
I did learn to not assemble the unions before soldering....a little solder in the wrong place will ruin your day.0 -
Again a little never seize goes a long way in preventing that!JUGHNE said:Those NIBCO brands have been pretty good.
I had to wipe the solder off of the taper of one...
I had a 1" black iron union from home depot that i had to replace with one from the real hardware store because it was leaking. A lot of times the iron ones have a brass seat in them.0 -
I have only used a couple dozen...0
I used two Viega unions today on a water filter housing, unfortunately both would weep afterwards, I tried reposition the pipe, added pipe dope to the thread and used more torque to tighten it, none mattered. The leak wasn't bad, just a drip or two every minute or so but I don't feel safe about it, didn't expect $30 a piece to perform like this. =(0
I think it is possible to distort and crush them with a prench that clamps down as you turn like a pipe wrench. i have also gotten them to seal with 2 very large wrenches. Remember the union nut is a couple sizes larger than the pipes it is mating together.0
The other press union sold on supplyhouse (JW) has a rubber gasket, maybe this type is less prone to leak than the ground joint type?0
@sunlight33
Surprised you had trouble with the Viega unions they are usually pretty good. Try some teflon tape and never seize0 -
Good news, I loosened the bracket holding the water filter housing and realigned the pipe to make sure it's square to the union, now the leak has stopped.
But the bad news is that the water filter housing starts to leak after I tighten it with a new O-ring.0 -
Yep, I learned something new today, tightening the nut on the union will not help align the pipe if they are not lined up to start with.0
Right now I am running pressure test with the filters before I put it into use. All joints and the filter itself are dry, but the pressure gauge is showing a pressure drop (1 psi every 1-2 hours), is this normal to be leak free?0
It is leaking somewhere but i'm not sure i would expect those o-rings on the housings to be airtight if you are testing with air.0
I am testing with water. So perhaps this is fine and I can move on to the next filter, got three more in the system, lol.mattmia2 said:It is leaking somewhere but i'm not sure i would expect those o-rings on the housings to be airtight if you are testing with air.
could be temp changes. if it is leaking where the water is you would see it0
If you're testing with water, and there is little or no air in the system, the pressure will be ridiculously sensitive to temperature. A good check, though, is to see if it stabilises when the temperature does, or better yet see if it goes back up in things get warmer.Br. Jamie, osb
No sign of going back up, still losing about 1 psi every 2 hours, someone suggested that the pressure relief button on the housing could be the culprit.
Another thing I learned is that if the system has no leak then the pressure gauge will start to rise as soon as I open the valve to let water in, because the water is compressing the air inside, it's a quick way to detect leak.0 -
are you pressurizing it from the municipal system and leaving it connected? try bringing it up to like half the municipal supply pressure and see if it slowly rises because the valve isn't holding.0
It has valves on both the inlet and outlet, so once it's pressurized from the city water I turned off both valves, the valves themselves should be leak free.0
should0
Look closely around the packing on the valves as well, although if it is a ball valve that should be sealed off when it is closed, I have bought a lot of ball valves with loose stem packing nuts. If they are sweat type valves the heat can cause the plastic to flow and become loose as well.0
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
