Sludge, Scale and Bouncing Boilers
HeatingHelp
Administrator Posts: 717
We once saw a boiler doing an Irish step dance on the basement floor. Yikes! Here are some tips to avoid boiler sludge and scale.
Great dissertation. Also the humor and descriptive terminology reminds me of some of your best works. The Problem Solver and Steam Without Tears. Still have many of those issues in my library.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Simply and well put.
On "closed" hydronic systems the non barrier tube will haunt us for generations. He is a steel sep that lasted 18 months on a high temperature rubber tube staple up. The home has seen 3 boilers in 20 years.
The high temperature systems really suck O2 through the tube. On a sealed, leak proof system oxygen ingress is the biggest cause of corrosion problems.Bob "hot rod" Rohr
Great article. I’m just a homeowner but wonder if it would be possible/make sense to manually feed distilled water into the boiler instead of boiling out the minerals with a separate hot water tank? Assuming a feed mechanism could be plumbed in.. does anyone do this or am I all wet? (figuratively speaking)0
I hope #3 went in with a hx and stainless/brass/bronze components on the radiant side...hot_rod said:Simply and well put.
The high temperature systems really suck O2 through the tube. On a sealed, leak proof system oxygen ingress is the biggest cause of corrosion problems.0 -
time to repair the leaking buried returns0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
