Sludge, Scale and Bouncing Boilers
HeatingHelp
HeatingHelp Administrator Posts: 725
edited May 2021 in THE MAIN WALL
imageSludge, Scale and Bouncing Boilers
We once saw a boiler doing an Irish step dance on the basement floor. Yikes! Here are some tips to avoid boiler sludge and scale.
Read the full story here
  • dopey27177
    dopey27177 Member Posts: 916
    Great dissertation. Also the humor and descriptive terminology reminds me of some of your best works. The Problem Solver and Steam Without Tears. Still have many of those issues in my library.
    Jake
    hot_rod Member Posts: 27,582
    Simply and well put.
    On "closed" hydronic systems the non barrier tube will haunt us for generations. He is a steel sep that lasted 18 months on a high temperature rubber tube staple up. The home has seen 3 boilers in 20 years.
    The high temperature systems really suck O2 through the tube. On a sealed, leak proof system oxygen ingress is the biggest cause of corrosion problems.
  • Wierling
    Wierling Member Posts: 8
    Great article. I’m just a homeowner but wonder if it would be possible/make sense to manually feed distilled water into the boiler instead of boiling out the minerals with a separate hot water tank? Assuming a feed mechanism could be plumbed in.. does anyone do this or am I all wet? (figuratively speaking)
    mattmia2 Member Posts: 16,985
    I hope #3 went in with a hx and stainless/brass/bronze components on the radiant side...
  • NYCBob
    NYCBob Member Posts: 1
    time to repair the leaking buried returns
