Painting of radiators
steamer45
Member Posts: 13
Any comments on the pro's or con's of painting radiators, more specifically, cleaning & then powder coating. Are any specific color's more reflective than others?
Twocomments. First, it's a pain to get all the old paint and rust off. It's also not really necessary, unless you are a fanatic. I use a good grade of interior acrylic paint on radiators (Benjamin Moore Aura) and have for years; if I manage to get the loose stuff off (scraper and wire brush) it lasts well.
With the advantage that I can match the room wall colour...
Second, avoid any metallic (silver, aluminium bronze, etc.) paints, as that can reduce the output of the radiator quite significantly. That is, unless you want to reduce the output such as the room is overheating and you can't control the radiator in some other way. Any other colour will have little or no effect on output.Br. Jamie, osb
Does anyone have a link to the old study that they did regarding the effect of different colors? I can't find it anywhereYou can have it good, fast or cheap. Pick two0
Retired and loving it.2
Dave Stroman in Denver may have information on how to restore these Jewels
I think he has them Sand blasted then Powder coated..
https://www.linkedin.com/in/dave-stroman-8a20262a?lipi=urn:li:page:d_flagship3_profile_view_base_contact_details;R0fdRSguRKaOyK947+i4XA== .
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
