Does a boiler require a specific type of drain valve?
stormbytes
Member Posts: 36
I have a Burnham IN6 steam boiler. I noticed last night the drain valve (I'm sure there's some other name for this part) located on the right side of the boiler was dripping. I tried googling for the part but I can't seem to find this part unless I google "water heater drain valve". Was this the correct part? What should I use to replace this? Do I need to add any fittings to extend this?
yes the drain valve from a water heater is the right replacement.
Jake
Steam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
My 2013 steam boiler had a slow drip at the boiler drain valve by year 2. Because of it's location I patched it with a brass threaded cap and teflon tape.
3PSI gauge0 -
With that type valve the bonnet is sealed with a gasket , there is no packing it may leak with a cap ... Crappy valve
Here's a Weil-McClain one but why do they shrink down the outlet like that?? I guess to provide the garden hose hookup. But I don't have any floor drains, so I just empty mine into a bucket anyway.
https://www.supplyhouse.com/Weil-McLain-511-246-392-3-4-Drain-Valve
I just used a full port ball valve with a nipple and a street elbow to aim the flow downward :
https://www.supplyhouse.com/Bluefin-BVT075-3-4-Full-Port-Threaded-Ball-Valve-Lead-FreeNJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
