Blazemaster CPVC pipe and fittings
BillyO
BillyO Member Posts: 277
I went to a job yesterday and contractor used Blazemaster pipe and fittings on the snowmelt side of heat exchanger from boiler room to outside manifold. He said he has been doing it that way for approximately 7 years. Any thoughts on this?
  • Zman
    Zman Member Posts: 7,611
    Albert Einstein
  • kcopp
    kcopp Member Posts: 4,628
    I also thought there was an issue using glycol in CPVC piping....
    hot_rod Member Posts: 26,575
    You need to use glycerin as an antifreeze in PVC. It should be available wherever they supply Blazemaster.
    It would be wise to use all non ferrous on the PVC side of the HX, as Carl mentioned.
