Blazemaster CPVC pipe and fittings
I went to a job yesterday and contractor used Blazemaster pipe and fittings on the snowmelt side of heat exchanger from boiler room to outside manifold. He said he has been doing it that way for approximately 7 years. Any thoughts on this?
  • Zman
    Zman Posts: 7,614
    Albert Einstein
  • kcopp
    kcopp Posts: 4,714
    I also thought there was an issue using glycol in CPVC piping....
    hot_rod Posts: 28,185
    You need to use glycerin as an antifreeze in PVC. It should be available wherever they supply Blazemaster.
    It would be wise to use all non ferrous on the PVC side of the HX, as Carl mentioned.
