Blazemaster CPVC pipe and fittings
BillyO
Member Posts: 277
I went to a job yesterday and contractor used Blazemaster pipe and fittings on the snowmelt side of heat exchanger from boiler room to outside manifold. He said he has been doing it that way for approximately 7 years. Any thoughts on this?
This came up back in 2014.
https://forum.heatinghelp.com/discussion/150482/cpvc-in-hydronic-heating-system
O2 ingress is the issue."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I also thought there was an issue using glycol in CPVC piping....0
You need to use glycerin as an antifreeze in PVC. It should be available wherever they supply Blazemaster.
It would be wise to use all non ferrous on the PVC side of the HX, as Carl mentioned.Bob "hot rod" Rohr
Living the hydronic dream0
- 109 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
