New Pex Thawing Tool
Riles_5
Member Posts: 13
Has anyone seen or heard of this new pex freeze thawing tool that's coming out?
It will prevent opening of walls to thaw a frozen obstruction in pex lines inside any inaccessible area.
Who is making it? Sounds interesting0
Must be a hair dryer
or a heat gun
I don't know what it could be unless they find a way to pass an electrical current through the water0 -
years ago there was talk of an ultrasonic thawing machine, vibrations really, but I never did see one.
A small diameter hot water catheter? We used 1/4" soft copper to thaw suspended sewer lines in underground parking structures. It can get messyBob "hot rod" Rohr
You are all in for a surprise. Thawing copper pipe with a welder is old hat. Harbor Freight has a new plastic welder. It may be just the ticket for those hard to reach pex places.
https://www.harborfreight.com/plastic-welding-kit-with-air-motor-and-temperature-adjustment-96712.html0 -
So what does welding plastic pipe have to do with thawing it?HomerJSmith said:You are all in for a surprise. Thawing copper pipe with a welder is old hat. Harbor Freight has a new plastic welder. It may be just the ticket for those hard to reach pex places.
Get with the program, folks--IT'S APRIL FOOLS DAY! Sometimes you guys are just too serious.0
Is this like flex seal and gorilla glue slapping their name on every chemical that has been in the hardware store for decades like it is a new product?0
Just saw a video for it, it thawed out a 4" freeze in 3/4" pex threw 8 fittings. The loop was about 40' and the tool was used from the return or supply end pretty amazing.0
Hi @Riles , Could you post a link to the video? I'd like to see this technology! Thanks
Yours, Larry0 -
Ill try, I don't have it, this Guy who invented it does.0
Cant get the video. It is coming to the market hopefully by next winter. Its a Game changer
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
