Tekmar help!
mattyc
Member Posts: 45
New tekmar 563 thermostat I just cannot get to turn on. I don’t understand what I am wiring wrong if someone is familiar with Tekmar’s products. I have a 1 stage heating system (baseboard heat) rh1 and w1 go to TT on aquastat and C- on the thermostat goes to a 24v common on a switching relay
Is the J1 jumper on? Can't tell.0
@MikefromMn yes I believe it is. I moved the black tab to the top0
Is your common coming off the same transformer as the RH1?
It looks like you need a jumper from RH1 to R. "J1""If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
