Baseboard heating water noise.
dmsmith396
dmsmith396 Member Posts: 1
My house has fin tube baseboard heat. I've been living here for 24 years and just recently I've been hearing the water moving through the lines. It sounds as if the system is low on water and is filling the pipes back up. Because I've never heard this in all the years I've lived here, I have to wonder if something is wrong with the system. TIA for any help.
    Jamie Hall Member Posts: 27,376
    Could be... somewhere on the boiler there should be a pressure and temperature gauge. Granted, it may not be all that accurate -- they usually aren't, even when they work -- but if you could take a look at it and tell us what the pressure is when the system is cool, and again when it's heating, and what the temperature is we can get a little further here.
  • HomerJSmith
    HomerJSmith Member Posts: 2,779
    Posting pics of your sys would be helpful.
