Hays Electroflo Zone Valves
Member Posts: 4,644
First time seeing these. Haven't been to the job yet, but they look to be line voltage.
If I had to guess, I'd say 1950's vintage.
I have always thought a solenoid valve was a great way to do hydronic zoning. Fast opening and that terrific fast closing feature... when the pipes rattled you knew the heat was definitely off. BANG!
Looks like time to repipe & rewire with new valves. Or maybe you could take the coil to a motor shop to have the solenoid coil rewound. Do they still have motor shops?Edward Young Retired
Google "Hayes Fluid Controls"
Still in business and still making control and solenoid valves0 -
There are ways to damp the shaft to solve that problem...EdTheHeaterMan said:I have always thought a solenoid valve was a great way to do hydronic zoning. Fast opening and that terrific fast closing feature... when the pipes rattled you knew the heat was definitely off. BANG!
Looks like time to repipe & rewire with new valves. Or maybe you could take the coil to a motor shop to have the solenoid coil rewound. Do they still have motor shops?0 -
More from the same job:
@Alan (California Radiant) Forbes
Were you able to fix up those solenoids or find any parts for them?0 -
Were you able to fix up those solenoids or find any parts for them?It was our first visit to the jobsite this morning. We'll replace those line voltage solenoids with 24 volt zone valves. We will also install a zone valve control, new thermostats, new relief valve, new fill valve and replace the copper natural gas supply line. All of these devices were original equipment and I feel good that with a minimum of effort, we can modernize the controls. However, I feel confident that these new devices will not last as long as what we're removing.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1
- 167 Indoor-Air Quality
