Always air-bound after vacation
When you get a chance show us the boiler and its related piping. Air's getting in and pictures could very well tell the story.
The obvious answer is to not go on vacation!
If that is not an option, then we need more information.
First is the location of the Unico air handler in reference to the boiler location. If the air handler is located several stories above the boiler, for instance, the static pressure of the water in the system may need to be increased.
Another possibility is that air from the expansion tank is finding its way to the air handler heat exchanger. Pictures of the boiler piping from ceiling to floor and from at least 2 different angles (more is better). And maybe some of the air handler piping.
Finally, what is your procedure for bleeding the air? that may also give a clue as to what is happening.
Looking forward to hearing from you.
Yours truly,
Mr.EdEdward Young Retired
I assumed the hydronic coil needed to be bled. I should have thought of that oil thing.STEVEusaPA said:When you say air bound, you mean the oil line that needs to be bled, correct?
I guess if you are a hammer, everything looks like a nail. I glossed over the Oil-fired statement and went for the air in the Hydronic System.
I made the same assumption about the hydronic side of the thing.
I, Betting on the Hydronic side too, but @STEVEusaPA has been correct once or twice before.Grallert said:I made the same assumption about the hydronic side of the thing.
So did I...Br. Jamie, osb
3 votes for Water... 1 for Oil.
I hope the OP returns to let us know who is right!Edward Young Retired
I assumed the hydro loop as well.
If it is the oil line, a Tiger Loop wont fix it. It might act liked it's fixed, but we all know it's not.0 -
If it looks fixed, and it acts like it's fixed, and it walks like it's fixed. Then it must be a Duck in a Tiger costume.
And you know that your comment is the only reason I posted that @HVACNUT. Now I can edit that out LOL
5 Hydro to 1 OILEdward Young Retired
Here's my favorite question! The system doesn't know you're on vacation--there must be some other change.Jon_blaney said:When you go away, what do you do to the system that is different than normal?
3 -
That's a great point, Ed, I totally missed that possibility
Still think @dpschuste just needs to stop all winter vacations, Paulethicalpaul said:
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
