Boiler replacement suggestions.
I would download the Slant Finn app and do a heat loss calc. You may be oversized now.
Is this steam or water?0 -
Look at installing a Trio cast iron three pass oil boiler with a indirect water heater.
When installing this boiler if you ever want to go to natural gas or LP gas you can change the burner.
Find a good professional heating contractor and they can help you out.
www.trioboiler.com0 -
Are the Trio boilers from fwwebb? I spoke w/ the local distributor when I was replacing the dhw mixing valve Granite group, and was told the Buderous is the cheapest. The burners Beckett, riello and Carlin were available. I would put a Carlin on it. As far as the indirect, any preference? Im looking for the best LT warranty.0
You're using the LT tank? Going stackable?
The G115-3 and the LT160 are a perfect match. Anything bigger is a waste for your needs.
Nothing wrong the the Carlin EZ-1, but what made you choose it?0 -
The Trio three pass boilers are a great choice. I service a few of them and I find that they are every bit as good as a Buderus. They work great with the Beckett AFG or Carlin EZ-1. The Trio with an indirect tank will give you noticeable fuel savings over your old Burnham with the tankless coil. The only boiler that I like more is the Energy Kinetics EK-1. I prefer a boiler with an indirect tank over a separate heat pump water heater, more reliable and easy to service. The choice of tank depends on the water quality in your area. Install a powered anode if you want it to last a long time.
I would stay away from ductless systems. I don't like the way black fuzzy growth builds up on the blower wheels of the indoor units in my area. As a service technician I find them to be a royal pain in the @$$ when they need service and repairs. Sometimes sourcing parts is a problem. I hate telling customers that their system will be down for a few days because the parts are being shipped from Japan. I'd rather install a traditional ducted system if possible. They are much better at removing humidity in the summertime due to the larger evaporator coils.0 -
Try to save yourself some work and before you rip it out you should remove the tankless coil and
replace the OEM gasket using a high temperature silicone if the manufacture recommends it as all you may need is a new gasket for the boiler.
The hold down nuts for tankless coils loosen over time if no blue loctite is applied to the stud threads.
its hot water baseboardEBEBRATT-Ed said:I would download the Slant Finn app and do a heat loss calc. You may be oversized now.
The Carlin for ease of service and parts.HVACNUT said:You're using the LT tank? Going stackable?
The plate and nuts are in very poor condition. I'm reluctant to even touch the tankless. If i look at it funny it may start leaking badly. The boiler is getting replaced in the spring. Just need it to last a few more weeks.0 -
LT as in lifetime warranty. I have well water. Never been tested and not on a softner or filtration system. Any thoughts on what tanks hold up best. I replaced a Triangle tube smart 50 at a friends house a couple weeks ago. Tank was only 3 years old. My friend had just purchased the house and Is having issues getting the tank warrantied due to not being original owner. I can see its TT policy but the tank is only a couple years old. Needless to say i will not be purchasing a TT for that reason.HVACNUT said:You're using the LT tank? Going stackable?
You need to get your water tested. At least just for water hardness.Fitzy_Fitta said:
The Viessmann VitoCell 300 tanks have a lifetime warranty to the original owner. They're the only tanks that do. There are exclusions for high chlorides or aggressive water. Test your water!!0
