Solution for adding a drain?
sunlight33
sunlight33 Member Posts: 378
My house is built on concrete slab above grade, there is no floor drain in the boiler room. If the PRV were to release water or a pipe burst water would have no where to go. What are some of the good ways to make it better? Put a sump pump on the floor? There is a sink in the room though.
    ethicalpaul Member Posts: 8,162
    edited March 2021
    For a water boiler or water heater, they don’t let everything out when they start to fail, they leak slowly I think.
    water detector alarms are super cheap on Amazon
    HVACNUT Member Posts: 7,231
    A lot of people put a 5 gallon bucket under the discharge pipe.
    If you pipe it to a drain, how will you know if there's a problem?
    ethicalpaulBillyO
    hot_rod Member Posts: 26,591
    A leak detection valve on the incoming water line could prevent a big flood. I'm not sure if a prv relief and fill valve trip would trigger them off?
    Where does the sink drain to?
  • sunlight33
    a little bit of water is fine, just don't want a fixture or a pipe burst to flood the entire floor. The sink drains to septic tank.
    Alan (California Radiant) Forbes Member Posts: 4,643
    edited March 2021
    My personal preference would be to tap into the sink tailpiece to add an indirect drain for the relief valve. It has a water seal at the p-trap to prevent sewer gas from coming into the room and an air gap to show you if it's leaking.
    mattmia2PC7060Intplm.
    A Y branch like Alan shows would work, they are intended for dishwasher drain when there isn't a disposal. Fine for boiler or AC condensate.
    Really you need a large floor drain or floor sink to keep up with a random burst pipe, especially a pressure water line.
    Chop a hole in the floor and add a plastic sump and pump if you are that concerned. Of course the pump needs a discharge.
