Help with the order of operation of this slab heat loss equation
toeknee
Member Posts: 20
Hey all, I have here an equation for heat loss but I can't seem to figure out the order of operation for it to get the same end result the writer did when plugging in the numbers from the example he gives along with it. Also, it was printed in the book twice but they don't match.
Anyone care to look at this and explain to me how to get the same result with the example numbers? Thanks!
Tony
Tony
Arizona
1. the equations aren't the same
2. you don't get the same answer they give using either equation0 -
It is correct in the 1995 edition:
once you fix the typo it is normal order of operations
exponents
multiplication/division
addition/subtraction
then multiply by 1 expressed as the denominator over the denominator or however you want to look at it to get rid of the denominator
looks like it should be .214 instead of .124. or there was a typo in the first edition and it got carried through the example answer in subsequent editions.0
Good eye, here is the correct formula. It was an editing mistake by the publisher.Bob "hot rod" Rohr
Living the hydronic dream1 -
I just checked my 2012 edition and it was incorrect like @toeknee 's.
Good catch, I made a note in mine. I usually just use the software, but occasionally for weird ones I will build a spreadsheet based on the formulas in the book"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Because it is the perimeter term it being off by about a factor of 2 doesn't make a lot of difference in the final result in most cases.0
LOL, I actually emailed him about this mistake and another. I heard back about the first, but not the second.
@STEVEusaPA oops, I did too
@mattmia2 yeah it doesn't seem to make any critical difference. Someone would have to have a HUUUUGE cut-up building for this to cause anythingArizona0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
