Help with the order of operation of this slab heat loss equation
toeknee
toeknee Member Posts: 20
Hey all, I have here an equation for heat loss but I can't seem to figure out the order of operation for it to get the same end result the writer did when plugging in the numbers from the example he gives along with it. Also, it was printed in the book twice but they don't match.
Anyone care to look at this and explain to me how to get the same result with the example numbers? Thanks!
Tony
Arizona
    mattmia2 Member Posts: 16,145
    1. the equations aren't the same
    2. you don't get the same answer they give using either equation
    It is correct in the 1995 edition:
    once you fix the typo it is normal order of operations
    exponents
    multiplication/division
    addition/subtraction
    then multiply by 1 expressed as the denominator over the denominator or however you want to look at it to get rid of the denominator
    edited March 2021
    looks like it should be .214 instead of .124. or there was a typo in the first edition and it got carried through the example answer in subsequent editions.
  • Zman
    Zman Member Posts: 7,611
    edited March 2021
    I have gotten lazy and just type the formulas into Excel...
    @mattmia2 is correct, Ill have to go look at my version.
    Albert Einstein
    hot_rod Member Posts: 27,127
    Good eye, here is the correct formula. It was an editing mistake by the publisher.
  • toeknee
    You guys are all way too good!! Thanks! Its a good thing they put example problems in the book or I would've gone on using the formula with the typo. Then I would've put it into excel like @Zman does, except my formula would be wrong the whole time
    Arizona
  • Zman
    I just checked my 2012 edition and it was incorrect like @toeknee 's.
    Good catch, I made a note in mine. I usually just use the software, but occasionally for weird ones I will build a spreadsheet based on the formulas in the book
    Albert Einstein
  • Zman
    I am kind of laughing that no one even mentioned the book title...
    For those scratching their heads, It is Modern Hydronic Heating, AKA "The hydronic heating bible".
    Albert Einstein
    Because it is the perimeter term it being off by about a factor of 2 doesn't make a lot of difference in the final result in most cases.
  • STEVEusaPA
    LOL, I actually emailed him about this mistake and another. I heard back about the first, but not the second.
  • toeknee
    @STEVEusaPA oops, I did too
    @mattmia2 yeah it doesn't seem to make any critical difference. Someone would have to have a HUUUUGE cut-up building for this to cause anything
    Arizona
