Additive/ Subtractive Pressuretrols?
Robert O'Brien
Robert O'Brien Member Posts: 3,584
edited February 2021 in THE MAIN WALL
Why make both?
    Jamie Hall Member Posts: 26,840
    Very different histories to the two lines.
  • Robert O'Brien
    Yielding the same results
    Well, actually not quite. The line which produced today's vapourstats -- now including higher pressure range subtractive pressuretrols -- has a different fundamental mechanism (and initially used mercury, not mechanical, switches). It is not quite as robust, but has much better precision and slightly better accuracy. The mercury switch ones were far superior in that regard, as well as longevity -- provided they weren't overpressured at some point -- but ... well... mercury was deemed by Those Who Know to be the Worst Thing That Ever Happened.
    It's a little like saying a Ford and a Mercedes yield the same results. They do. But they aren't the same.
