Additive/ Subtractive Pressuretrols?
Robert O'Brien
Member Posts: 3,541
Why make both?
Very different histories to the two lines.Br. Jamie, osb
Jamie Hall said:Very different histories to the two lines.To learn more about this professional, click here to visit their ad in Find A Contractor.0
Robert O'Brien said:Jamie Hall said:Very different histories to the two lines.
Yielding the same results
Well, actually not quite. The line which produced today's vapourstats -- now including higher pressure range subtractive pressuretrols -- has a different fundamental mechanism (and initially used mercury, not mechanical, switches). It is not quite as robust, but has much better precision and slightly better accuracy. The mercury switch ones were far superior in that regard, as well as longevity -- provided they weren't overpressured at some point -- but ... well... mercury was deemed by Those Who Know to be the Worst Thing That Ever Happened.
It's a little like saying a Ford and a Mercedes yield the same results. They do. But they aren't the same.Br. Jamie, osb
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
