heating a room in basement 15 x30 area
creger.robert
Member Posts: 108
in Gas Heating
any thoughts on how to heat this area in basement-used as a office very cold
In floor radiant!0
How is the rest of the house heated? We are going to need a bit more info..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Electric baseboard is cheap and easy to install. Or they make small electric cabinet heaters.
But cost $$$$ to run.
But you have givein us no information to go on0
- 123 Chimneys & Flues
