wood boiler code question
hot_rod
Member Posts: 25,325
Is it NFPA 211 that covers solid fuel boilers? Are their EPA requirements in play now for emissions. @Bob Harper anyone up to speed on code requirements for placement, venting, etc?
Not sure about NFPA, In Colorado, lot's of regs have popped up at the local level. Most areas require EPA 2 cert and distance to neighbors or minimum lot size."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Hello Bob,
NFPA 211:
"Standards for chimneys, fireplaces, vents, and solid fuel burning appliances".
The forest eaters especially (outdoor wood boilers/water stoves) have come under a lot more regulation and limitations in their allowable locations with regard to zoning.0 -
I guess I may need to buy a download of 211 to get some answers, thanks.
Feel free to contact me with that other question on the buffer idea. PM me here or bob.rohr@caleffi.comBob "hot rod" Rohr
I'm leaning towards the Wohler 450. Touch screen, ap, everything on a single screen, no scrollong around for the different readings Found them for 1287 at test instruments
https://www.youtube.com/watch?v=3BdpmXCxRZU
Living the hydronic dream1 -
211 is just for combustion venting. You can view it for free online here: https://www.nfpa.org/codes-and-standards/all-codes-and-standards/list-of-codes-and-standards/detail?code=211
Solid Fuel-fired boilers are listed under UL 2523. Neither of these stds. cover emissions or efficiency. Here is from the EPA: https://www.epa.gov/residential-wood-heaters/fact-sheet-summary-requirements-wood-fired-hydronic-heaters . Here is an article that does a good job explaining some of the difficulties with efficiency testing of solid fuel fired boilers: https://woodboilers.com/wood-boiler-efficiency-and-epa-ratings/ . Meanwhile, a growing number of jurisdictions are outlawing them. You can also contact the Hearth, Patio, and BBQ Assn. in Arlington, VA and talk with their Gov't Affairs head, John Crouch. HPBA.org
HTH !1 -
Trying to find out what the code states about a locating a wood fired boiler in a shop or garage.
Absolutely no? Or sealed combustion allowable? Or 18" above the floor was once allowed.Bob "hot rod" Rohr
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
