Boiler occasionally not firing?
seanbeck1
Member Posts: 23
Hi guys looking for some help here.
I have a Slant-Fin conventional gas fired boiler feeding 3 zones with one circulating pump and 3 zone valves.
Twice in the last week I’ve noticed my house getting cold. Gone into my boiler room and noticed that the boiler was not firing. Yet there was a call for heat in all three zones and the circulating pump is running.
It’s almost like the pilot light is going out and then not re-lighting. It’s a self igniting pilot.
I’ve been able to fix this by turning the boiler on and off and then it will fire. I hear the ignition and then the burners kick in.
I had some drywall/sanding done in my basement recently. Could this have affected anything in my boiler?
Thanks guys.
Thanks guys.
Most likely the pilot burner is dirty. Blowing on the pilot burner openings with a piece of tubing, ort a can of compressed air that computer repairmen use will usually do the trick.
Thank you very much I will try that. I should remove the pilot assembly, clean and then re-install?EdTheHeaterMan said:Most likely the pilot burner is dirty. Blowing on the pilot burner openings with a piece of tubing, ort a can of compressed air that computer repairmen use will usually do the trick.0 -
Most people forget about the heating system until there is a problem. Most people do regular maintenance on their car BEFORE there is a failure. I wonder why that is? The automotive industry did a better job of requiring maintenance for the warranty to be valid. The boiler industry not so much.
Read the manual that came with the boiler. There is a section called Maintenance. If you do your own car maintenance then you can probably do your own boiler maintenance. If you "have a guy" to do the car... you should have another guy for the heater. Guy = Gender non-descript and can also be male, female, or whatever the other genders are
Yours Truly,
Mr.Ed
If you have a long enough tube, you could blow it out in place!
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
