Fields controls auto damper wiring help
BestJersey
Member Posts: 2
in Gas Heating
Good evening,
My d80d auto damper died after a long life. I have a Utica m150agb boiler. I ordered a fields gvd 7 pl as a replacement with the wiring kit. I need help connecting the aquastat wiring to the new damper. The aquastat is a L1848E and does not accept the molex from the kit. I’ve done a bit of googling and I cannot determine the correct terminals to connect the four wires from the damper to my system. Your help is appreciated.
Ultimately, the damper and aquastat are not compatible. The damper was removed.0
Sorry just read this posting there is a way to wire it.0
- 15.8K Strictly Steam
