UFT80 slight knocking sounds
PC7060
Member Posts: 1,750
I’ve noticed my UFT80 occasionally makes a slight knocking sound when firing at low rates. Not very loud and comes and goes. Sound seems to be coming from the top of the firing chamber and reminds me a bit of expanding metal knocks.
Is this typical system noise?
System is running fine with no performance issue.
Hard to say without actually hearing it.
I have noticed that some fire tube HXs have a slight popping and cracking noise which is probably caused by micro bubbles. It seems that no matter how good the MBR works, they do it anyway. It could also be micro steam flashes in miniature crevices of the HX that don't get good flow.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
