Bosch greenstart floor stand combi
Jrthen323
Jrthen323 Member Posts: 13
edited February 2021 in Gas Heating
Just install it yesterday but today cant get the heat to turn down thermostat call for heat thermostat set to 70 but its 81 degrees event wen the boiler its off the baseboard still push some heat
  • Jrthen323
    Please  help
  • GW
    GW Member Posts: 5,134
    How many zones? They are all hot? This gotta be simple—-pull the stat wire off the boiler and see what happens
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • Jrthen323
    Its only a single zone
  • Jrthen323
    Yeah all the baseboard are hot i just put it on the eco mode to see what happens to see if they cool off
  • Ironman
    Ironman Member Posts: 7,842
    Why won't you follow Gary's advice and remove the stat wire from the boiler to see what happens?
    Bob Boan
  • Jrthen323
    Because i just left its a friend house  and i just left but definitely im goin to do it first thing in the morning
  • GW
    Or at least turn down the maximum temperature knob, so you don’t cook.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • Jrthen323
    Ok i got the TT desconected and my basebord cool off so what you think it could be
  • GW
    Your low voltage wiring is messed up. How many zones? Maybe you pinched a wire?
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • Jrthen323
    Its a single zone
