Bosch greenstart floor stand combi
Jrthen323
Member Posts: 13
Just install it yesterday but today cant get the heat to turn down thermostat call for heat thermostat set to 70 but its 81 degrees event wen the boiler its off the baseboard still push some heat
Please help0
How many zones? They are all hot? This gotta be simple—-pull the stat wire off the boiler and see what happens0
Its only a single zone0
Yeah all the baseboard are hot i just put it on the eco mode to see what happens to see if they cool off0
Why won't you follow Gary's advice and remove the stat wire from the boiler to see what happens?Bob Boan
Because i just left its a friend house and i just left but definitely im goin to do it first thing in the morning0
Or at least turn down the maximum temperature knob, so you don’t cook.0
Ok i got the TT desconected and my basebord cool off so what you think it could be0
Your low voltage wiring is messed up. How many zones? Maybe you pinched a wire?0
Its a single zone0
