What's a word for the opposite of Primary-Secondary piping?
JohnNY
Member Posts: 3,358
Is there a word for sending the whole system through the boiler or should I invent my own term? Direct Flow Piping? Mono-Loop Piping? I've been saying "standard" but it always requires explanation.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
That's what I've always called it. If the system is hydraulically separated from the boiler loop, it's primary secondary. If the system pump generates flow to the emitters and the boiler, it's piped "directly". If you said you set it up with direct flow piping, I'd know exactly what you were referring toYou can have it good, fast or cheap. Pick two3
Direct or direct to boiler piping, maybeBob "hot rod" Rohr
Its a good question. Language is important. Common terminology would help folks on this forum convey clear information, if there WAS a proper, common term for what you are asking about.
Say, wasn't this forum founded by a well known writer with a thorough knowledge of hydronics? Maybe he has the term you're looking for!0 -
Anyone look at what modern hydronic heating and idronics call it?0
Take your pick.
From Modern Hydronic Heating
Series loop is called 'Single Series Circuit"
One pipe is called "single circuit multizone"
Then there is "Multi zone with zone valves
Then there is "Multizone with circulators"
"Parallel with direct return"
"Parallel with reverse return"0 -
For what it's worth, "direct connection" used as a verb, not a noun:
Thanks, guys. Good answers here. It's best to standardize the terms and it comes up quite a bit in our industry.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0
- 50 Industry Classes
