Radiator Valves
rhw1
Member Posts: 32
Should the valves in a one pipe system have some accumulation of water? If so does the water need to be emptied periodically? Thanks.
Just clarifying do you indeed mean "valve" or do you mean "air vent"? Anyway, the answer is the same: there will always be some water. And No, if they are properly operating and oriented, there is never a need to empty them.
But to help you, why are you asking?NJ Steam Homeowner.
@rhw1 are you referring to the supply line (those are the main pipes mostly in the basement sending steam to radiators) having water accumulated or return line (brings the condensate / water once radiators cool down) and a having water? ... like @ethicalpaul asked r u referring to a valve or air vent (there are main air vents on supply line and radiator air vents on each steam radiator)? can you clarify.. if not sure post a pic of it... thanks and best!0
It is the air vent on the end of the radiator. After raising one of my radiators over a period of time (1/4 to 1/2" at a time ) and making sure it slopes back to the valve the thing still has an annoying set of loud ticks while heating up. Someone here suggested putting on a slower vent. So when changing out the air vent some water came out and I wondered if that may have been the problem. Obviously not.0
Ahh gotcha. It was probably OK. it kept ticking after raising it, eh?
Although it is a radiator farthest from the boiler, in a colder room,should I now try a slower vent? I think that's my last hope?0
Can’t hurt to try
If the radiator is ticking, that's expansion, not hammering. It may be the radiator, it may be the pipes. Changing vents won't help -- but making sure that the radiator and pipes can expand freely will.Br. Jamie, osb
"but making sure that the radiator and pipes can expand freely will"...... and how do you do that?0
On the pipes -- look at where they come through the floor, or where they are supported or run through joists -- if you can get there! -- andparticularly where they come through the floor, make sure they don't touch or, if they do, slip a piece of slippery plastic -- such as a piece cut from a polyethylene milk jug -- in there. On the radiator itself, I've had some success (not always -- no guarantee) with slipping similar pieces under the feet of the radiator, so it can slide more easily.
Doesn't always work...Br. Jamie, osb
- 50 Industry Classes
