Galvanized Hangers
Tom_133
Member Posts: 962
So my wholesaler like most others out there tends to try to cripple me daily.
This time it was an order for 50- 1.5" copper emlocks they shipped galvanized. I didnt want the guys standing around so I said put em up, and worse case, I will run back in a few days and replace them with copper. I was curious if anyone has seen a product I can put between the hanger and copper to avoid that. My insulator may be able to put some paper and a bit of insulation, but I would sleep better knowing the copper will never touch the galvanized.
If I have to swap them so be it.
thanks
Tom
thanks
Tom
Tom
Montpelier Vt
Montpelier Vt
I have used 2" wide vinyl electrical tape. Called "Amazing Super Duper Multi-Purpose Tape", 2" X 108'. I buy it by the 6-pack from Jacobseninc.com .....800-243-7473...in Adair, IA. Their number for it is ADTT.
Someone close to you must have it. Handy for many things, AC lines, large wire pulls etc.0 -
If you have enough clearance flat roof membrane works well. Even inner tube will work in a pinch.0
I’d consider something like felt or Christie’s 10mil tape..0
All the "copper" hangers I've seen will stick a magnet!
I'd use super 88 or some other tape especially if it will be insulated over.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
