Proper Venting does = Savings!!!
AdmiralYoda
Member Posts: 721
So thanks to you guys I've installed main vent (didn't have any) and improved the venting on the radiators.
I just got my gas bill for December..... compared to last year the average temperature was the same and the heating degree days were pretty darn close.
I used 14.3% less therms! The price per therm has gone up so the cost savings year over year was more like 8%. But if price/therm was the same that would be a 14.3% savings! That is pretty substantial!
My boiler is 40% oversized and my near boiler piping is a complete mess. I can only imagine the difference when I install a delay timer to reduce short cycling and correct the near boiler piping.
Maybe another 5-10%?!?!
Instead of a DIY delay timer, I suggest you take a look at the Hydrolevel VXT with the intermittent test function I have mentioned in other discussions. No extra wires, just buy the one with the proper voltage for your system. Go for the digital readout, too so you can monitor makeup amounts.
In other discussions, some guys have commented on them. For my use, with an oversized boiler in a rental property, it's the safest solution.0 -
Inexpensive, simple, easily installed, doesn't confuse the next tech. What's not to like?SteamingatMohawk said:Instead of a DIY delay timer, I suggest you take a look at the Hydrolevel VXT with the intermittent test function I have mentioned in other discussions. No extra wires, just buy the one with the proper voltage for your system. Go for the digital readout, too so you can monitor makeup amounts.
In other discussions, some guys have commented on them. For my use, with an oversized boiler in a rental property, it's the safest solution.Br. Jamie, osb
Thanks guys, I'm going to check that out! I have a manual water feeder now so I would definitely like this.0
@AdmiralYoda : Here is a video on the features of the VXT water feeder. I hope it helps.
https://www.youtube.com/watch?v=kF4WpyZdt4s&list=PLPrJrk_ajqswojOz
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
@Jamie Hall @Gordo
I checked it out....pretty cool and will function exactly as I want it to. And the techs will have a clue what's going on.
Question. How do you set the baseline water level? Install the probe where you want the waterline to be when all the steam is in the pipes and radiators?
If you get one of these and your arrangement would have the readout upside down, @Gordo has a Youtube video on how to modify the case so the valve can be rotated 180 degrees. It's not hard to do, just be careful when you put it back together.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
