flue gases with old CI rads on conventional gas boiler
kensheets2
kensheets2 Member Posts: 36
edited January 2021 in Plumbing
Hello
I understand that with low water temp installations such as radiant floor heating, return water temps will naturally be less than ideal. My question is if I am running an application using old cast iron rads with a conventional gas boiler and running water around 170-180 will I realistically still need to be concerned with low return water temps in relation to flue gas condensation?
Thanks
Ken
    Jamie Hall Member Posts: 27,392
    Probably not. The concern arises when the return water to the boiler drops below about 140 -- and stays there -- while the boiler is running. Mostly a control issue. Make sure the boiler is set to hold a source temperature high enough, and to make sure there is enough circulation.
    Ironman
