Radiant PEX heat transfer plates and route around 2" drain pipe...
RodHot
Member Posts: 22
I have a run of aluminum heat transfer plates that layout direct in the path of a 2" shower drain. See photo, is the following "route around" look acceptable? I was concerned that the spacing between the short aluminum plates was too close together? I could take the two 16" aluminum plate sections out and put in place two 12" aluminum plate sections. This would allow a bit more space for the PEX pipe.
Thank you
Thank you
Why are 2 pex pipes entering 1 plate?0
Only 1 PEX pipe is being used for this entire run.0
1/4" spacing should be more than enough with the tube has nice bend(not sharp). Aluminum plates expands and contracts base on temperature but not that much more than 1/16" so...u should be fine....I have similar installed at my home and never noticed the plates is even expanding much...Thank you,
Hiren Patel0 -
Why don't you notch the plates around the pipe to get a straighter run?0
notching, I did not consider that. Not a bad idea, I could even use the hole saw to cut a nice clean "arc" through the area of the plate where the drain hole is.0
I think this is going to haunt you.
Steve, Yes, agreed this was a concern I had. This is something I addressed in another post...
https://forum.heatinghelp.com/discussion/181953/route-pex-around-wood-blocking
The general thought was a "loop" around the wood blocking in such a way that it will not rub or touch. This could be accomplished by using some fastener / mounting method like a Talon.0 -
I had some situations similar to yours where the plates couldn't line up.
I decided to cut the plates down and allow for a 12" space between plates. This way if the pex was contracting and expanding, the raw edge of the plate wasn't working against the pex.0
- 50 Industry Classes
