Banging pipes at specific times
JodiMe
Member Posts: 117
Hi. My pipes and system are generally very quiet but occasionally in the morning, when coming up to day time temp, we get some major banging in them.
A bit before we usually get out of bed, we set it from overnight temp (66) to 68 so we can muster the strength to get out of our warm covers. Then an hour later, as we are getting up and at em, we have it go up to 69. The banging almost always seems to happen just as we start that second cycle.
Anyone know why this could be? It doesn’t seem to happen at any other time.
hot water? Steam?Br. Jamie, osb
Steam0
The long run from 66 to 68 is producing a lot of condensate -- and somewhere... hard to say where... some of it is hanging up long enough so that when the heat comes back on, it bangs. Question is... where?Br. Jamie, osb
That makes sense. Maybe we will play with the timing settings a little and see if we can get in the sweet spot where it doesn’t happen. It’s not every morning but even once in a while it’s concerning/annoying.0
Look for a pipe or pipes that have lost their pitch or have a sag in them and correct the pitch or sag. If the banging sounds like it is coming from under a floor board, near a radiator, try to raise that end of the radiator to get the pitch back, in the pipe under the floor board, and then re-pitch the radiator.1
Thanks for the help. I know exactly where it’s coming from so I’ll take a look. We do have a fast vent on that specific radiator since it’s at the opposite and of the house from the boiler and is pretty sizable.0
How do I check this?0
Oh, never mind. I’m slow on the uptake today! I’ll double check those...0
