Whistle noise from Beckett AFG burner on Rand Reardon Boiler
etabor
etabor Member Posts: 5
edited December 2020 in THE MAIN WALL
My new Reardon Rand boiler with Beckett AFG burner whistles, or makes a harmonic type noise.  I have good flame, good draft (tested using a smoke machine) and zero carbon or soot. Any ideas would be great.  Ed
    HVACNUT Member Posts: 7,231
    I never heard of that manufacturer so I did  a search. Makes sense now.
    What did the smoke machine show?
  • etabor
    Good draft smoke pulled out.  Ed
    EBEBRATT-Ed Member Posts: 19,579
    Sometimes you just have to play with things to find out why it;s making noise.
    So you have draft and 0 smoke. Did you check Co and Co2. If not your still running blind
    Alan Welch
    Nice! I wouldn't expect anything less.
    Time to call a pro.
    etabor
  • etabor
    I pray you were not being snarky.  I installed it myaelf.  Cannot afford 12500 to 15000 to have somebody install it.  And, if I do say so I did a pretty damned good job.  2 minor leaks Now fixed.  Never sweated copper before.  Filled it bled it and fired it without issue.  Ed
    HVACNUT
    Steamhead Member Posts: 18,203
    @etabor , we're not being snarky. Unless you have a digital combustion analyzer and the know-how to use it, it's time to call a pro.
    Boilers do not come pre-set from the factory. No installation is complete without a combustion analysis. Your family's safety is at stake.
    Where are you located?
    Consulting
  • etabor
    York PA area
    If you can't find someone local to set up your burner, call us. We've been known to come up that far.
    Consulting
    HVACNUTZman
  • etabor
    thank you for the offer.  I called Anthony’s Affordable Heating Cooling and he is to be out in less than a week now.  When I called he was scheduling 3 weeks out.
