Update from Sudbury On Canada
Synway
Member Posts: 48
Well Monday Dec 7 we will get another step forward. Having health issues sucks when even firing a contractor
What’s a good wireless thermostat. I don’t want these bozos drilling in my walls running wires.
Well the latest is the initial contractor has folded his business. So I’ve called in a new contractor. As far as the thermostat goes, I wanted to avoid running low voltage wire to the 4 locations and use a wireless system for the thermostats. However the new contractor suggested to have the wired thermostats.0
Wired t-stat are the most reliable. No batteries to mess with or RF interference. If you have reasonable access above or below and you can run wires only having to fish a wall or two, that is the way to go. Pull more conductors that you think you need, the wire is the cheap part.
If you need to go wireless, Honeywell has some good products."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Much better,
Just waiting for the gas company to upgrade the regulator and a couple connections we will have heat. Thanks for the support and advise from all0 -
