Looking for a diagram to install a new boiler :)
I need to replace my old now dead Utica Boiler with a Buderus GB142 and Buderus indirect hot water heater. I'm looking for a layout diagram to plumb the new to the old. The old system used cast iron radiators which I'll keep.
I'm not sure if it's allowed on this site, but I would have no problem paying for this as a service.
Thanks so much for any help!
-Mike
-Mike
There's a diagram in the boiler's Installation & Operation manual included with the unit.
Every boiler has one.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes5 -
Just made this conversion myself from a large cast-iron boiler to a modern HTP UFT modulating condensing boiler.Take a look here for diagram from manual on my thread.I’ll also post my updated drawing today1
I need a plumbing to English translator for it. I'm just not 100% on how to layout the zones, if I can use PEX to copper/what diameter, where the magnetic filter should be setup, what size expansion tank I need, if anything can be installed to guard against the various metals flowing through the aluminum boiler, etc.JohnNY said:There's a diagram in the boiler's Installation & Operation manual included with the unit.
That's how long I've been sitting on this...Robert O'Brien said:The GB142 was discontinued a couple of years ago?
Thanks, I'll take a look at that. I'd still rather work from a diagram for my system. I've read on here some guys provide that as a service.PC7060 said:Just made this conversion myself from a large cast-iron boiler to a modern HTP UFT modulating condensing boiler.
Take a look here for diagram from manual on my thread.I’ll also post my updated drawing today0 -
Well then that's a very different thing you're asking for. System design and layout is to some extent site specific. Maybe someone here will help you.MAF said:
Classes1 -
I am using the steel Low Loss Header that came with the boiler. It's where a little confusion comes in on my part as the supply and return inputs are 1.5" so I wasn't sure if I had to plumb to the zones with that size. The existing cast iron radiators are plumbed with 1 1/4" copper.Ironman said:You have to use the Low Loss Header (or similar one) that comes with the boiler.
Are you replacing an existing boiler or installing a new system?
I'm replacing the ancient cast iron Utica Boiler. I'd like to replace all the associated valves, bleeders etc as well.
- 120 Geothermal
