Pump coupler caught on fire
ddyckmam3
ddyckmam3 Member Posts: 1
The pump coupler on my Beckett AFG burner caught on fire today . Any ideas what might have caused this ? It melted the CAD eye as well .
  • BDR529
    BDR529 Member Posts: 376
    Exhaust fan in the room? Power vent? Direct vent?
    Seen them melt when pulling air down the chimney
    Jamie Hall Member Posts: 27,376
    Pump free to rotate?
  • STEVEusaPA
    Back pressure. Plugged heat exchanger, blocked chimney, and/or negative room pressure pulling products of combustion backwards thru the burner.
    Also incorrect burner set up, and on furnaces, cracked heat exchanger, clogged filter with an open return.
    Figure it out before you fire it back up.
  • SuperTech
    SuperTech Member Posts: 2,661
    Back pressure. Plugged heat exchanger, blocked chimney, and/or negative room pressure pulling products of combustion backwards thru the burner. Also incorrect burner set up, and on furnaces, cracked heat exchanger, clogged filter with an open return. Figure it out before you fire it back up.
    All of the above are the usual possibilities.  The only time I ever saw this happen the heat exchanger was plugged with soot and the homeowners kept resetting the burner.
    You have major problems. The burner is not safe to operate until the cause is identified and corrected. Call a pro who is familiar with oil heating systems.
    Steamhead Member Posts: 18,501
    This.
    @ddyckmam3 , where are you located?
    Consulting
  • 426hemi
    426hemi Member Posts: 86
    It is a furnace if so did the air handler door fall off or did you change the filter? If it runs without the door it will pull negative pressure and suck the flame out the burner.  Also everything else everyone has said.
