General heating question
Maybe its a stupid question, I am obviously not a plumber....
Also, the manual lever will only hold the valve open temporarily. Once there's a heat call to it and it's satisfied, the valve will shut.Bob Boan
The question is whats the penalty, its a pretty short loop, room is next to boiler. I don't need heat there, but say once a week when I do, it takes forever to go from 50s to upper 60sEBEBRATT-Ed said:No there is no such thing as free heat. If you don't need heat ther leave it off. When on it will take longer to heat your other zones. No Free Lunch
Id leave it set around 60-62 on the thermostat when you aren't using the room. That should take care of your problem. The heat won't be wasted, it will just be waiting for your arrival.kolyan said:No there is no such thing as free heat. If you don't need heat ther leave it off. When on it will take longer to heat your other zones. No Free Lunch
The question is whats the penalty, its a pretty short loop, room is next to boiler. I don't need heat there, but say once a week when I do, it takes forever to go from 50s to upper 60s0 -
The penalty is higher fuel cost for supplying heat to the basement when you don’t need it. If some heat is diverted to the basement when the upstairs zones are on, the burner will run a bit longer.—
Bburd0 -
I see. Well thanks. I guess I'll just keep doing it the same way. Heat is set to 58F there, when I need to use basement ill just set it to 68F. Boiler is condensing so water temp is lower that's why
It takes a while to heat up. My understanding is that considering boiler work best with fixed temperature on thermostats, but at the same time if I don't need heat at night or in basement, it just makes no sense to run it.
If you are in the basement the same time each day you could get a programmable T-stat and set it to come on a couple hours before you go down...0
Yes I know. No its always different times now. Planning to make a small gym there so maybe it will be more consistent. Now its a playroomkcopp said:If you are in the basement the same time each day you could get a programmable T-stat and set it to come on a couple hours before you go down...
When you heat the basement, a portion of that heat is lost to the walls, windows, floor, etc. A heat load calc would help show what that loss is at all those surfaces.
But you would also reduce the load on the floor above by having a warm basement.
In the end, heating both spaces will take more fuel and add cost.
It would certainly help to insulate the basement, paying particular attention to the rim joist. There tends to be a lot of infiltration loss where the plate contacts the foundation. 20 bucks worth of spray foam can help lessen those losses.Bob "hot rod" Rohr
Rim joist already sprayed, thanks. Its just one room in basement, roughly 1/4 of basement space, so above is only 1 room too.hot_rod said:When you heat the basement, a portion of that heat is lost to the walls, windows, floor, etc. A heat load calc would help show what that loss is at all those surfaces.
It would certainly help to insulate the basement, paying particular attention to the rim joist. There tends to be a lot of infiltration loss where the plate contacts the foundation. 20 bucks worth of spray foam can help lessen those losses.0
