Radiator valve fixed shut?
pnm2
Member Posts: 56
In troubleshooting one of my radiators that never heats, I first noticed the shutoff valve doesn't turn all that much in either direction before stopping, and so I thought I'd start there.
I discovered that there appears to be some sort of permanent "wall" keeping it closed (see photo).
I don't know why someone would've done that, but it is fairly close to the thermometer so maybe that's the reason?
In order to open things up, do I need to replace the valve entirely or is there some other way to open this "wall"? Or am I better off keeping it closed due to its proximity to the thermometer? I was thinking I'd throw a #4 vent on it, since I'm partial to the idea of all my radiators operating, even if some to a lesser degree.
That's a gate valve. When open that "wall", known as a gate, will lift up opening the valve. Need to get it freed up to allow for flow so the radiator will heat.2
How do I open it? The valve hardly turns, and when it does there's no change to the gate.0
How much is it turning? Gate valves typically take a lot of turns to open completely, sometimes a turn or 2 before you see much movement.pnm2 said:How do I open it? The valve hardly turns, and when it does there's no change to the gate.
Very little. Maybe a quarter turn, tops. Maybe I need to put a lot more muscle on it? It just felt like it came to a pretty complete stop, but I haven't yet tried excessive force since it felt like it was at the end of its turn.0
Glad to help.1
- 116 Geothermal
- 15.8K Strictly Steam
