Radiator Identification/ Questions
mojito
Member Posts: 2
Hi there,
just have a couple questions about this radiator system. Both pipes come out of the same side with nothing on the other side. (see attached picture). is it a one pipe or two pipe system, and is it safe to shut one of these radiators off while others in the same building are running?
thanks.
thanks.
This is a two pipe system.Yes, it is safe to shut individual radiators off.Is this a steam or hot water system? Is there an air vent of any kind on the radiator? Probably on the other end.—
Bburd0 -
it does have a small sort of set screw/ valve on the top/side of the fins (same end as the pipes) which releases air when unscrewed?
That type of vent is generally used on hot water rather than steam systems.—
Bburd0 -
That is almost certainly a hot water system, and yes you can shut the valve off. It looks as though it hasn't been used for a while, though, so when you shut it off you may well find two things: first, it won't shut off tight and second, it will probably leak around the valve stem. Just so you know...Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
