Radiator Identification/ Questions
mojito
mojito Member Posts: 2
Hi there,
just have a couple questions about this radiator system. Both pipes come out of the same side with nothing on the other side. (see attached picture). is it a one pipe or two pipe system, and is it safe to shut one of these radiators off while others in the same building are running?
thanks.
  • bburd
    bburd Member Posts: 1,314
    This is a two pipe system.
    Yes, it is safe to shut individual radiators off.
    Is this a steam or hot water system? Is there an air vent of any kind on the radiator? Probably on the other end.
    Bburd
  • mojito
    it does have a small sort of set screw/ valve on the top/side of the fins (same end as the pipes) which releases air when unscrewed?
  • bburd
    That type of vent is generally used on hot water rather than steam systems.
    Bburd
    Jamie Hall Member Posts: 27,513
    That is almost certainly a hot water system, and yes you can shut the valve off. It looks as though it hasn't been used for a while, though, so when you shut it off you may well find two things: first, it won't shut off tight and second, it will probably leak around the valve stem. Just so you know...
    Canucker
