oil line
mikelee
Member Posts: 7
can i make a two pipe oil furnace into a one pipe the new tank outlet is 8 t0 10 inches lower than pump inlet?
can anyone help with this0
can anyone help do i need to change pump for this?0
o well i will check else where0
lol,0
need help can imake a two pipe oil furnace into one pipe furnace.tank outlet is about 10 inches lower than pump inlet0
new to this where do i get answers ?0
Yes. But it isn't a completely straightforward job, and requires some specialized equipment -- and knowledge.Br. Jamie, osb
You have multiple threads asking the same question... see other comments.Br. Jamie, osb
Here is the easy way to do it.
https://www.supplyhouse.com/Tigerloop-Oil-De-aerators-25270000?gclid=CjwKCAiAwrf-BRA9EiwAUWwKXi1DVxZB91OcnPMIIGr52rSHzSUhdtyXuwYaER3ZozQaBZW9-iTMchoCht0QAvD_BwE
I always used the ULTRA because it comes with a great oil filter. but if the oil filter you have is still good, then use the standard Tigerloop. It gives you all the benefits of a single pipe from the tank and all the benefits of a 2 pipe system.
You won't need to remove the bypass plug in the fuel pump and you don't need to redesign the piping at the burner.Edward Young Retired
@mikelee
You change the oil pump from 2 pipe to 1 pipe by removing the bypass plug.
You really need to call a professional if you don't know how to do this. And respectfully if you have to ask the question you don't. Do yourself and your family a favor and call your oil supplier or service tech1 -
I've merged the duplicate threads into one here.
President
HeatingHelp.com0
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
