oil line
mikelee
mikelee Member Posts: 7
edited December 2020 in Oil Heating
can i make a two pipe oil furnace into a one pipe the new tank outlet is 8 t0 10 inches lower than pump inlet?
  • mikelee
    can anyone help with this
  • mikelee
    mikelee said:
    how to change a two pipe oil line pump to a one pipe syetem
  • mikelee
    can anyone help do i need to change pump for this?
  • mikelee
    o well i will check else where
    Jamie Hall Member Posts: 26,807
    We seem to be in a bit of a rush, here, don't we?
    MaxMercyHVACNUTmattmia2SuperTech
  • Dave T_2
    Dave T_2 Member Posts: 64
    lol,
  • STEVEusaPA
    5 posts in less than 20 minutes, at lunch, on the coldest day of the season so far, with NE in a snow/freeze/power out mess.
    First of all why? My guess is your system has a 2 pipe, you think (or confirmed) your pump is bad, you bought another one.
    MaxMercyHVACNUTRobert O'Brien
    HVACNUT Member Posts: 7,211
    Too late. He converted to gas.
    mattmia2STEVEusaPARobert O'Brien
  • mikelee
    need help can imake a two pipe oil furnace into one pipe furnace.tank outlet is about 10 inches lower than pump inlet
  • mikelee
    new to this where do i get answers ?
    Yes. But it isn't a completely straightforward job, and requires some specialized equipment -- and knowledge.
    You have multiple threads asking the same question... see other comments.
    EdTheHeaterMan Member Posts: 11,552
    Here is the easy way to do it.
    https://www.supplyhouse.com/Tigerloop-Oil-De-aerators-25270000?gclid=CjwKCAiAwrf-BRA9EiwAUWwKXi1DVxZB91OcnPMIIGr52rSHzSUhdtyXuwYaER3ZozQaBZW9-iTMchoCht0QAvD_BwE
    I always used the ULTRA because it comes with a great oil filter. but if the oil filter you have is still good, then use the standard Tigerloop. It gives you all the benefits of a single pipe from the tank and all the benefits of a 2 pipe system.
    You won't need to remove the bypass plug in the fuel pump and you don't need to redesign the piping at the burner.
    SuperTech
    EBEBRATT-Ed Member Posts: 19,491
    @mikelee
    You can but why would you want to? Is your oil tank inside or outside?
    @mikelee
    You change the oil pump from 2 pipe to 1 pipe by removing the bypass plug.
    You really need to call a professional if you don't know how to do this. And respectfully if you have to ask the question you don't. Do yourself and your family a favor and call your oil supplier or service tech
    HVACNUT
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    I've merged the duplicate threads into one here.
    President
    HeatingHelp.com
