Setting up ODR
Suzook
Suzook Member Posts: 221
I am having issue maintaining temp on my 2nd zone on 2nd floor. Its as insulated as well as possible, but most of my issue is not enough fin tube. This year, not an option to add any. Once we hit around 30 at night, i cant maintain the setpoint. So i should increase min supply temp, correct? Thanks
    EdTheHeaterMan Member Posts: 12,165
    edited December 2020
    If you have operated without ODR in the past, and you did not experience this problem in the past. Then you are correct. the higher temperature in the existing elements will provide more heat.
    This means that your other zones/areas will cycle off more often.
    Nice Car!
  • Suzook
    Thanks! On both. LOL
  • motoguy128
    motoguy128 Member Posts: 393
    Make sure the fins are clean and there’s a gap if possible behind furniture.
    If you raise the temp but reduce the flow rate you might get more heat without hurting efficiency.  Efficiency depends on return water temp not supply temps.  But it’s a fine line.  You do get a little more capacity with flow.  What’s the delta T now?
  • Suzook
    Fins are clean, with space from furniture. Unfortunately, they put in as little as possible fin tube, but it worked using 180 degree supply temp. I actually got a degree more increasing the flow. I dont know what my Delta T is. Ant cheap digital thermos out there? Im not worried about efficiency at the moment, more about maintaining setpoint, and long cycles. The long cycles i am getting.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    If you have central AC shut all the room defusers or vents the lead up into the cold attic ...
    Suzook
  • Suzook
    Well, damn. I forgot about those upstairs. I did them down, not up.
